Top level resource folder not working in FME flow
  • Nov 3, 2025 3:11 PM UTC
  • 106 views
jonathan_vru
Forum|alt.badge.img+10
I am trying to make a custom top level resource folder work, but i can't write the output of my apps and workspaces to the folder.
If i try to write output to the custom folder, it fails almost immediately, and when i inspect the logfile it just says
  • Log Error
  • The log file for job ID "816" does not exist.
Did i forget some steps in the configuration of the custom folder? Or what did i do wrong?
Thanks in advance for the help!
For reference what i did:
Adding Top-level resource folder in FME Flow | Community
Best answer by zoe.forbes
Hi Jonathan,
Creating a top-level folder in Resources via fmeflowconfig.txt causes the folder to appear in the UI, but does not create a macro. This means $(FME_SHAREDRESOURCE_MOI) will not be recognised by Flow when the workspace is run (assuming this is the SHAREDRESOURCE_NAME value you set, from ​@frro’s answer).
To mimic the expected behaviour from macros referencing top-level Resources, you can create a Deployment Parameter with name FME_SHAREDRESOURCE_MOI and value “C:\ProgramData\Safe Software\FMEFlow\resources\moi” or wherever the new moi folder is located. This allows $(FME_SHAREDRESOURCE_MOI) to be recognized in User Parameters or within Workspaces.
Please let me know if you have any questions about this!
zoe.forbes
Forum|alt.badge.img+11
  • Nov 6, 2025 7:22 PM UTC
Hi Jonathan,
