Reinstalling with same license code ?
Hello,
I run free FME desktop 2020.0 (free home edition) on Linux Mint 19.3. The upgrade check for LM 20 warns me that FME will be removed. Would I be able then to install FME 2020.1 using the same licence code I was given or do I need to request a new one ?
Best answer by catatsafe
Hi @groschialeux,
Home Use license codes are single-use, so if you need to re-license you will need to request a new code.
Forum|alt.badge.img+50
You should be able to use the same serial number.
  • July 17, 2020
Hi @groschialeux,
catatsafe wrote:
Hi @groschialeux,
Thanks, that's what I thought.
