Reinstalling with same license code ?
  • Jul 17, 2020 1:19 PM UTC
  • 75 views
Hello,
I run free FME desktop 2020.0 (free home edition) on Linux Mint 19.3. The upgrade check for LM 20 warns me that FME will be removed. Would I be able then to install FME 2020.1 using the same licence code I was given or do I need to request a new one ?
Best answer by catatsafe
Hi @groschialeux,
Home Use license codes are single-use, so if you need to re-license you will need to request a new code.
Forum|alt.badge.img+63
You should be able to use the same serial number.
  • Jul 17, 2020 3:31 PM UTC
Hi @groschialeux,
Hi @groschialeux,
Thanks, that's what I thought.
