Linux installation of FME Server failed but I ran it as root! line 403: ./install.sh: Permission denied
  • January 12, 2017
  • 28 views
fmelizard
Forum|alt.badge.img+21
I am logged into my Linux machine as root, and tried to run the installer.
sudo ./fme-server-b16716-linux-x64.run
After granting all permissions, it still doesn't work.
sudo chmod 777 fme-server-b16716-linux-x64.run
This is the error I received:
Verifying archive integrity... All good.
Uncompressing FME Server 2016.1.3.1................................................................................
/usr/safe/./fme-server-b16716-linux-x64.run: line 403: ./install.sh: Permission denied
What can I do?
rylanatsafe
Forum|alt.badge.img+14
  • January 12, 2017
Try the following command sequence to extract the FME Server files, and then manually invoke the install.sh file. Let us know if this doesn't work for you!
./fme-server-b16716-linux-x64.run --noexec --keep cd fme-server ./install.sh
You may need to prefix all the commands with sudo if you are not logged in as root. If this is successful, you can delete the fme-server folder that was created in the same directory as the .run file.
