I am trying to deploy FME Flow Helm chart to AWS EKS. We also have an external DB in AWS RDS Postgresql DB which needs to be used along with AWS EFS for shared data directories and AWS ALB for ingress.
  • Jan 12, 2024 11:40 AM UTC
  • 5 replies
  • 129 views
I'm have created a storage class and persistent volume according to their documentation (https://docs.safe.com/fme/html/FME-Flow/AdminGuide/Kubernetes/Kubernetes-Deploying-to-Amazon-EKS.htm)
This is my helm install command:
helm install fmeserver safesoftware/fmeserver-2023-0 --set fmeserver.image.tag=21821-20220728 --set deployment.ingress.general.ingressClassName=alb --set storage.fmeserver.class=efs-sc --set deployment.deployPostgresql=false --set storage.fmeserver.accessMode=ReadWriteMany --set fmeserver.database.host=mycluster.rds.amazonaws.com --set fmeserver.database.adminUser=user --set fmeserver.database.adminPasswordSecret=fmeserversecret --set fmeserver.database.adminPasswordSecretKey=password --set fmeserver.database.user=user --set fmeserver.database.name=fmeserver --set fmeserver.database.password=password --set fmeserver.database.adminDatabase=postgres --set deployment.startAsRoot=true -n gis-fmeserver
Now my core pod is failing with the following details:
Screenshot 2024-01-10 at 2.55.30 PMAll the other pods are failing with the following errors:
Screenshot 2024-01-10 at 2.56.42 PMNote that the EFS being used here is also in use by other services. Please share any insights that will help me with fixing these issues.
paalpedersen
Forum|alt.badge.img+8
  • Jan 15, 2024 1:55 PM UTC
To me it looks like there a problem with your PersistenVolume type. Does your volume type support ReadWriteMany? Persistent Volumes | Kubernetes
I have followed their documentation to create the persistent volume.
apiVersion: v1
kind: PersistentVolume
metadata:
 labels:
  app.kubernetes.io/managed-by: Helm
 annotations:
  meta.helm.sh/release-name: fmeserver
  meta.helm.sh/release-namespace: gis-fmeserver
spec:
 capacity:
  storage: 10Gi
 volumeMode: Filesystem
 accessModes:
  - ReadWriteMany
 persistentVolumeReclaimPolicy: Retain
 storageClassName: efs-sc
 csi:
  driver: efs.csi.aws.com
  volumeHandle: fs-********::fsap-********
And I have provided the storage.fmeserver.class=efs-sc in the values.yaml file to use that storage class. And I've given the name of the PV as fmeserver-data because that is what it will be looking for.
I've also tried the option startAsRoot as true in the values.yaml file.
paalped
Forum|alt.badge.img+11
  • Jan 16, 2024 8:51 AM UTC
apiVersion: v1
metadata:
 labels:
 annotations:
spec:
 capacity:
  storage: 10Gi
 accessModes:
  - ReadWriteMany
 csi:
Did you look at this doc:
https://docs.aws.amazon.com/eks/latest/userguide/efs-csi.html
apiVersion: v1
metadata:
 labels:
 annotations:
spec:
 capacity:
  storage: 10Gi
 accessModes:
  - ReadWriteMany
 csi:
I've taken a look at this. But I'm not sure what I should be looking for. Can you please help me with it.
I was able to solve this issue, in the pv.yaml file, I provided the wrong EFS access point ID. I gave the posix user access point ID instead of the root user access point ID initially, it's fixed now after providing the root user access point ID.
