How to start a desktop workspace from server?
  • Nov 19, 2018 2:51 PM UTC
  • 95 views
I am using FME Server 2018 and FME Desktop2018. My goal is to get informed and run a workspace, if a change was made in a specific directory. The FME Server has no internet connection, so I need another solution than the email-notification. My plan ist to run a directory watch by the FME Server and trigger a workspace to start running on my FME Desktop, which opens a command line window with a message inside.
The other workspace contains a geocoder transformer, so an internet connection is needed. As I mentioned the server has no connection to the internet, so it definitely has to be executed on the FME Desktop.
Is it possible to run a workspace with FME Desktop, initiated by the FME Server?
I thought I could add a network-based resource to get access to the .fmw, but in the subscription options I am only able to add workspaces stored in the repositories.
Any ideas?
erik_jan
Forum|alt.badge.img+26
  • Nov 19, 2018 3:00 PM UTC
You can run FME Desktop, using the SystsemCaller transformer from a workspace on FME Server.
The SystemCaller can run a batch file running the command line for FME Desktop (e.g. fme.exe myworkspace.fmw).
Hope this helps.
  • Nov 19, 2018 3:35 PM UTC
Hope this helps.
On FME Desktop it works by using your solution, but after uploading it to the server the process runs and doesn't get to an end :(
  • Nov 19, 2018 3:40 PM UTC
Hope this helps.
Note: I granted a full access permission to the server and used the UNC-path to the .bat
