Hello Admin, I installed FME 2020 on windows 10 pro and I am unable to open it for usage as it shows me error like ''FME WORKBENCH HAS STOPPED WORKING''..I have also tri using the command window to scan for sfc/scannow yet it didn't solve the error i
  • Mar 31, 2021 10:45 AM UTC
  • 5 replies
  • 74 views
The image of the error is attached here..Thank you as I await a solution to the issue. let me also state that FME 2018 and 2019 ARE WORKING PERFECTLY WELL on my computer except, FME 2020 AND 2021.
Forum|alt.badge.img+63
Try downloading and installing again, see if that fixes it.
  • Mar 31, 2021 11:36 AM UTC
I have done this several times , yet it didn't fix the issue
daraghatsafe
Hi @chielobe​ is there a particular action that is causing FME to stop working? Or is it not opening at all? Are there any Windows updates or graphics driver updates that need to be installed?
  • Mar 31, 2021 6:49 PM UTC
It do happen once I click to open FME 2020 or 2021, it will pop up the workbench error message and all my drivers have been updated. Yet this issue persist.
daraghatsafe
Hi @chielobe​ can you run through the steps in this article https://community.safe.com/s/article/Debugging-FME-Workbench-Stopped-Working
it may give us some clues as to what is going on here, thanks.
