FME server secure Active Directory connection error
  • Aug 5, 2020 10:13 AM UTC
  • 255 views
I get this error:
(Active Directory) Exception: "An error occurred while attempting to connect to xxxxxxxxxxxxxx:636: IOException(LDAPException(resultCode=91 (connect error), errorMessage='An error occurred while attempting to establish a connection to server xxxxxxxxxx/xxxxxxxxx:636: SSLHandshakeException(sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target), ldapSDKVersion=4.0.14, revision=c0fb784eebf9d36a67c736d0428fb3577f2e25bb'))"
I followed instuctions, googled, watched video's but still no solution and struggling.
  • port 636 is open to communicate over SSL with LDAP
  • certificate is installed in java keystore and added to cearts
  • port 389 unscure is working in FME server with AD
No valid certification?
With program keystore explorer everything looks fine
But I am not expert in certification.
Requested target?
This should be FMEServer\\Utilities\\jre\\lib\\security\\cacerts? because I noticed that there's also another path \\Server\\fme\\jre\\lib\\security
not that's working.
I also checked and configured some related xml-files
Any Ideas?
richardatsafe
Forum|alt.badge.img+11
Hi @adejong​ ,
FMEServer\\Utilities\\jre\\lib\\security\\cacerts is the correct place. You may have to add both the Root and Issuing Certificate to the cacerts file. If you have already done that feel free to make a case and ourselves or our partners can help with some more hands on help.
https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Import_CA_Certificate_for_SSL_Connections.htm
