FME Server - Invalid URL in push notification configuration
  • Nov 12, 2013 4:27 PM UTC
  • 62 views
Hello,
Using the FME Server publishing wizard from FME Workbench, I configured my workspace to run whenever a topic was notified (subscribed to topic).  No errors were generated during completion of the wizard and the FME server web application shows no errors in the configuration of my subscription.  However, the workspace is never run when the topic is notified.  After hours of digging thru the logs, I finally found a warning in the '..\\logs\\notifier\\subscribers\\push\\push_XX.log' file:
WARN     802009     : Invalid target url for push notification: 'https://servername/fmenotification/UtilityStakingOperations/ProcessIncomingUtilityStakingEmails.fmw?opt_servicemode=async
I have no idea what's wrong with this url.  If I paste it directly into a new browser window and log in with the same credentials used in the subscription configuration, the job runs (although it fails as the FME Server Email reader recieves no content) and I can find it int he job history.  Also, for testing, I have another push subscription configured using the posttestserver.com site and this works just fine so I know my server is recieveing the email and notifying my topic correctly.
I've searched online extensively for any clue as to what the log message means with no luck.  I'm also waiting for safe support to get back to me.
Any help appreciated!
  • Nov 12, 2013 4:29 PM UTC
Just an update, when I posted this question I see the full url of my push subscription was abbreviated so here it is again:
