FME server 2021.2 and python compatibility(default settings)
  • July 28, 2025
  • 73 views
naveen
Forum|alt.badge.img+7
Hello Everyone,
I hope you are doing well.
I ran the below scripts to set it to custom python interpreter. I would like to know the default settings for FME server to revert back to original settings ?
 Thanks,
Naveen
toyosia
Forum|alt.badge.img+3
  • July 31, 2025
Hi Naveen,
Thank you for your question.
For FME Server 2021.2, the embedded Python versions are as follows, as referenced in Safe Software's Build Numbers article:
  • Windows: Python 3.8.9 and 2.7.18
  • macOS: Python 3.8.9
These are the default Python interpreters included with the installation. If you are configuring custom Python environments or require additional control over script execution in FME Flow (formerly FME Server), the following documentation provides helpful guidance:
Using Python with FME Flow
Cheers,
Toyosi A.
Technical Support Specialist, FME Flow
Safe Software Inc.
