FME Server 2018 Installation - Change queue hostname after installation
  • May 30, 2018 11:58 AM UTC
  • 42 views
lau
Forum|alt.badge.img+3
I have just installed an FME Server 2018.0.0.2 and I had problems to detect the engines. I did some researchs and I suspect that the queue hostname is the responsible. During the installation, I set it to "mypcname".
I saw in
https://docs.safe.com/fme/2018.0/html/FME_Server_Documentation/Content/AdminGuide/Install-the-FME-Servers-Failover.htm
that we should mention "localhost".
Is there a way to change this parameter after installing? I didn't find the file(s) where it is recorded...
Do you know where they are?
Thank you!
  • May 30, 2018 12:40 PM UTC
I've done exactly the same thing you describe (naming the queue with the real hostname) and it worked without a hitch in my case.
Are you sure that's the problem?
