Azure Kubernetes Service - Unmet Persistent Volume Claims
  • August 22, 2021
  • 93 views
sam.seamless
TLDR: When deploying FME Server to Azure Kubernetes Service set storage.fmeserver.size to at least 100Gi in values.yaml to meet Azure File Storage minimum requirements.
When deploying FME Server to Azure Kubernetes using Azure Files as per the documentation, the default 10Gi setting fails to meet Azure minimum size requirement for a file share in a Premium_LRS type sku storage account.
The default values.yaml file has the following settings:
storage:
  useHostDir: false
  reclaimPolicy: Delete
  postgresql:
    class:
    path:
  fmeserver:
    accessMode: ReadWriteOnce
    class: azurefiles-fmeserver
    path:
When applied, the following pods will fail to be scheduled:
  • engine-standard-group x2
  • core
  • queue
  • websocked
However fmeserver-postgresql, will be scheduled successfully and should run. Looking into a failed pods description, for example the core pod:
kubectl describe pods core-0
We can see the issue is due to an unmet persistent volume claim.
Conditions:
  Type           Status
  PodScheduled   False
Volumes:
  fmeserverdata:
    Type:       PersistentVolumeClaim (a reference to a PersistentVolumeClaim in the same namespace)
    ClaimName:  fmeserver-data
    ReadOnly:   false
  default-token-8fpkj:
    Type:        Secret (a volume populated by a Secret)
    SecretName:  default-token-8fpkj
    Optional:    false
QoS Class:       Burstable
Node-Selectors:  <none>
Tolerations:     node.kubernetes.io/memory-pressure:NoSchedule op=Exists
                 node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
                 node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Events:
  Type     Reason            Age                 From               Message
  Warning  FailedScheduling  6s (x7 over 4m32s)  default-scheduler  0/1 nodes are available: 1 pod has unbound immediate PersistentVolumeClaims.
Upon further inspection of the persistent volume claim request, we see that it is stuck on pending due to an invalid header.
kubectl describe pvc fmeserver-data
Results in the following output:
Namespace:     default
StorageClass:  azurefiles-fmeserver
Status:        Pending
Volume:
Labels:        app=fmeserver-2021.0.3
               app.kubernetes.io/managed-by=Helm
               chart=fmeserver-2021.0.3-0.2.29
               heritage=Helm
               release=fmeserver
               safe.k8s.fmeserver.build=21326
               safe.k8s.fmeserver.component=data
Annotations:   meta.helm.sh/release-name: fmeserver
               meta.helm.sh/release-namespace: default
               volume.beta.kubernetes.io/storage-provisioner: kubernetes.io/azure-file
Finalizers:    [kubernetes.io/pvc-protection]
Capacity:
Access Modes:
VolumeMode:    Filesystem
Used By:       core-0
               engine-standard-group-c9965f769-4jhxq
               engine-standard-group-c9965f769-s2dg5
               queue-0
               websocket-0
Events:
  Warning  ProvisioningFailed  7m49s  persistentvolume-controller  Failed to provision volume with StorageClass "azurefiles-fmeserver": failed to create share kubernetes-dynamic-pvc-37b1fbf1-5174-45e9-85f4-69bc5b67916d in account fmedatastorebroken: storage.FileSharesClient#Create: Failure responding to request: StatusCode=400 -- Original Error: autorest/azure: Service returned an error. Status=400 Code="InvalidHeaderValue" Message="The valuefor one of the HTTP headers is not in the correct format.\nRequestId:9a9d1d3e-601a-0029-7326-971af7000000\nTime:2021-08-22T07:22:23.6903962Z"
Azure/AKS GitHub issue 5156 highlights that this message is erroneous and actually due to Azure Premium File Storage having a minimum size requirement of 100gb for the sku type Premium_LRS - which is required in order to have File Storage.
The simple solution is to modify the values.yaml file for your deployment so that storage.fmeserver.size is at least 100Gi.
storage:
  useHostDir: false
  postgresql:
    class:
    path:
  fmeserver:
    path:
This parameter is used in Safe's Helm charts to define a persistent volume claim, which provisions the file share within the storage account created in step 3:
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
  labels:
    safe.k8s.fmeserver.component: data
    {{- include "fmeserver.common.labels" . | indent 4 }}
spec:
  {{- with .Values.storage }}
  accessModes:
  - {{ .fmeserver.accessMode }}
  {{- if and (not .useHostDir) .fmeserver.class }}
  storageClassName: {{ .fmeserver.class }}
  {{- end }}
  resources:
    requests:
      storage: {{ .fmeserver.size }}
  {{- end }}
sam.seamless
  • August 22, 2021
@stewartatsafe​ , @grantarnold​  and @claudeatsafe​ , I see you three are maintaining the helm charts in Github and likely the installation documentation. Just tagging you in so you are aware, I suspect that this is an Azure specific issue and easily fixed with the values.yaml file, but might be something to highlight for others.
