AttributeCreator getting "Bad variant index in get" when setting default value to adjacent feature attribute
  • Oct 10, 2018 2:44 PM UTC
  • 10 replies
  • 106 views
Trying to set "WeekOfMonth" attribute for ALL features based on attribute "feature[-1]._4weekly_cycle" value, which today is "2". I am using the adjacent feature attributes capability in "AttributeCreator" transformer. Getting "Bad variant index in get" error in log file. If I set default value to "2", it works. Something not write with handling "feature[-1]._4weekly_cycle" value.
  • Oct 10, 2018 2:46 PM UTC
  • Oct 10, 2018 2:58 PM UTC
Forum|alt.badge.img+54
  • Oct 10, 2018 2:59 PM UTC
I think this could be a problem with the first feature, since there will never be a previous feature for the first feature. Try using a conditional formula for the attribute value to handle the first feature
  • Oct 10, 2018 4:01 PM UTC
Thanks, I tried using a conditional. That did not help.
  • Oct 10, 2018 4:18 PM UTC
I've looked at the workspace now, I don't think you want the adjacent attribute handling. Do you just want to add the calculated Week of the Month to every feature coming out the first part of the workbench?
  • Oct 10, 2018 4:24 PM UTC
  • Oct 10, 2018 4:25 PM UTC
Yes. Just add the calculated Wek of the Month to every feature.
  • Oct 10, 2018 4:28 PM UTC
I would just use a featuremerger for something like this, so all features going into the requestor, your calculated Week of the Month to the supplier and use 1 on both sides of your Join, e.g.
  • Oct 10, 2018 4:36 PM UTC
I'll try using the featuremerger. Thanks for the example. I've never used FeatureMerger.
  • Oct 10, 2018 4:52 PM UTC
That worked! Thanks. I really appreciate your time in looking at it. I figured there was a better way to merge the data, I did not realize you could use the featuremerger that way without unique keys. Thanks.featuremergeradded.png
