ZipExtractor alternative
  • Oct 14, 2019 6:51 AM UTC
  • 8 replies
  • 219 views
nielsgerrits
Forum|alt.badge.img+67
I use the ZipExtractor and ZipArchiver custom transformers by @takashi from the Hub on FME Server 2016 for multiple processes. Now we are migrating to FME Server 2019 and these are not sustainable because of Python incompatibility. I found the FileCopyWriter can work as an alternative for the ZipArchiver. Does an alternative for the ZipExtractor exist?
The alternative is I try to upgrade the ZipExtractor to Python to 3.x but as my Python-fu is not amazing...
I know Readers can read directly from Zip but my current proces unzips the entire Zipfile and then processes the different unzipped files.
sigtill
Forum|alt.badge.img+25
  • Oct 14, 2019 8:23 AM UTC
- Creator
- FeatureReader (Directory and file pathnames) and point to the zip-file
you will get one feature per file within the zipfile
- FeatureWriter (FileCopy) and set an outputcatalgue.
So you can use the Directory and file pathnames to read files within the zipfile and filcopy to write them to the destination folder.
nielsgerrits
- Creator
Many thanks @sigtill!
  • Oct 14, 2019 9:44 AM UTC
I think both ZipExtractor and ZipArchiver work with Python 3.x interpreter too.
nielsgerrits
Not sure how to check, but when I load it I get the "Python Version Compatibility Mismatch" screen.
  • Oct 14, 2019 10:17 AM UTC
The warning message appears when adding the transformer which was created with Python 2.7 environment and FME Workbench changes the Python Compatibility parameter to Pyhon 2.7, but you can re-set the parameter to Python 3.x manually after adding the transformer.
nielsgerrits
Very nice, many thanks for the addition. I always get confused and not sure what happens with Python related errors.
nielsgerrits
@takashi if you convert the comment to answer I can mark it as the correct answer.
