ZipArchiver: Zipfile size requires ZIP64 extensions
  • Jul 12, 2018 10:09 AM UTC
  • 192 views
soothsayers
Forum|alt.badge.img+7
Using FME Server, I am writing a large amount of data to a gdb to then be zipped up, using the custom transformer ZipArchiver. It works until it reaches its 2GB limit and then fails with the following lines:
Ideas for a workaround for this would be gratefully received! Is there a quick fix? Would Gzip work better?
Kind regards
Best answer by david_r
Edit the custom transformer and open the PythonCaller. Modify line 63 to set "allowZip64" to True. The line should look like this:
with zipfile.ZipFile(zpath, 'a', zipfile.ZIP_DEFLATED, allowZip64=True) as zipper:
Perhaps @takashi would consider making this the default for the next release? :-)
  • Jul 12, 2018 10:22 AM UTC
  • Jul 12, 2018 10:33 AM UTC
@david_r, thanks for your suggestion. Yes, setting True to the allowZip64 flag could resolve the issue.
Setting Python 3.4+ (or later) to the Python Compatibility parameter in the workspace could also be a solution, since the allowZip64 flag is set to True by default in Python 3.4+.
  • Jul 12, 2018 11:03 AM UTC
Updated the ZipArchiver in FME Hub to allow zip64 by default :-)
soothsayers
  • Jul 12, 2018 11:46 AM UTC
Thanks guys, this seems to have worked :)
