ZipArchiver fails - unicode not defined
  • Nov 27, 2020 5:26 PM UTC
  • 49 views
soothsayers
Forum|alt.badge.img+7
I am using both Desktop and Server and occasionally get issues with the ZipArchiver failing. I have attached a log file where you can see it at the end.
Python Exception <NameError>: name 'unicode' is not defined
Python is not my forte! Does anybody know what causes this?
Many thanks,
Glenn
  • Nov 30, 2020 8:06 AM UTC
First, check that you have the latest version of the ZipArchiver installed, see https://hub.safe.com/publishers/pacific-spatial-solutions/transformers/ziparchiver
Next, check the Python version set in the workspace properties. If it's version 2.7, try setting it to Python 3.7 (or whatever is available in the list), or the other way around.
soothsayers
  • Dec 9, 2020 8:14 PM UTC
Thank you for your response, and sorry for the delay! I have upgraded the transformer and will report back if I still encounter issues.
We run everything with Python 3.7+
