Zip multiple CSV files with different schemas - Reader warning
  • April 6, 2017
  • 142 views
tim_wood
Forum|alt.badge.img+8
I have several CSV files with different schemas that I would like to put into a Zip file before sending via the Emailer. Using the CSV2 Reader (*.csv, Identical Schema NOT ticked) with the CSV2 Writer (Zip file name as Destination CSV and fme_basename as CSV File Name in Writer) seems to work, but I get warnings like this in the Translation log:
2017-04-06 12:22:58| 1.1| 0.0|WARN |CSV reader: Attribute 'wibble' exists on the schema but was not found in the file. This attribute will not be read
I assume this is something to do with the differences in schemas of the different CSVs being read but I just wanted to crowd source some reassurance that this is nothing to worry about!
pratap
Forum|alt.badge.img+12
  • April 6, 2017
If you change the input file but not the feature types present as readers then this warning will appear. If you are confirm that this feature type contains data then you have to revisit and see why it is not reading else proceed.
itay
Forum|alt.badge.img+19
  • April 6, 2017
Direct copy paste from the FME desktop Basic manual:
"Every time FME reads a dataset, it checks the feature types inside that dataset to ensure that they are all defined within the workspace schema. If there are feature types that exist in the dataset, but do not exist in the workspace, then features are classed as "unexpected" and filtered out by a function called the Unexpected Input Remover. The actions of the Unexpected Input Remover are reported in the Log file:
STATS |Router and Unexpected Input Remover(RoutingFactory): Tested 3995 input feature(s), wrote 3995 output feature(s): 957 matched merge filters, 957 were routed to output, 3038 could not be routed ...and also through a dialog that opens
Remember that there are two different types of file dataset: file-based and folder-based. For file-based datasets, if there is a layer in the file that is not represented on the canvas then FME treats the layer as "unexpected" and drops it from the translation. This most commonly happens when the layers in the source data change, or a completely different file is selected. For folder-based datasets - where layers are stored as separate files in a folder - if there is a selected file that is not represented on the canvas, then FME treats the file as unexpected and drops it from the translation."
Hope you are reassured now...:)
tim_wood
  • April 6, 2017
I think for clarity I will use separate Readers. In fact, I've added the Zip Writer as a second output in another Workspace which does other stuff to the CSV files.
With *.csv I only end up with 1 Feature Type called CSV in the Reader (Merge Feature Type is NOT ticked).
I had also tried using the Path Reader and FileCopy Writer as a way of Zipping the CSV because I don't really want to be handling schemas, just Zipping the files. However I couldn't get that method to work.
