Xquery and FME
  • February 12, 2013
  • 0 replies
  • 10 views
A while ago, I posted a question about rendering maps using FME and I was shown the Cartopgrahic Rendering Tricks webinar done by Dotted Eyes.
I'm currently working on reproducing this (amoungst other things), but I've run into a bit of a snag when attempting to fill in the correct polyline symbol.
The information on the polyline is stored in an XML file, but I don't know Xquery well enough to phrase the command correctly.
The current query is
doc(Standard_Style_1.xml)/StandardStyle1/ColourPolygonStyles/g[id = coniferousTreeFillSymbol]
which returns
 |AreaSymbolizer_XQueryExtractor_StandardStyle1_ColourPolygonStyles_g_id__coniferousTreeFillSymbol__(XQueryFactory): The following error occurred near line 1, column 5 of the query:
12 14:19:30|  36.7|  0.0|WARN  |AreaSymbolizer_XQueryExtractor_StandardStyle1_ColourPolygonStyles_g_id__coniferousTreeFillSymbol__(XQueryFactory): evaluation of an expression relies on some part of the dynamic context that has not been assigned a value: {context item}.
Any help/ guidence as to how to solve this particular challange would be welcome
Thanks in advance
Be the first to reply!
