XMLTemplater with subtemplate not retaining nesting correctly
  • Nov 9, 2017 6:57 PM UTC
  • 100 views
chriswilson
Forum|alt.badge.img+29
I have the following root template in an XMLTemplater:
Where {fme:process-features("FEATURE_CLASSES") occurs I want to insert the following subtemplate within the sequence elements, grouped by an attribute so that it repeats according to how many feature classes I have:
The result, however, loses the nesting and leaves elements retreating to the root element level - the subtemplates start inserting at row 6 with the first element showing in the correct position:
What can I do to avoid this, or is it just a case of using a separate templater for the subtypes and then appending them into the root in an XMLAppender?
Best answer by takashi
Hi @chrisw84, if you need to adjust indentations, consider using the XMLFormatter in the subsequent workflow.
  • Nov 9, 2017 10:57 PM UTC
chriswilson
  • Nov 9, 2017 11:07 PM UTC
Hi @takashi, the problem is that the indentations are not being preserved in the first place - adjustment should not be required?
  • Nov 9, 2017 11:12 PM UTC
Indentations in XML documents are only for human convenience. Machine ignores excess whitespaces (space, tab, newline, etc) within XML documents.
chriswilson
  • Nov 9, 2017 11:53 PM UTC
Good, point, however it would be useful if the visual indentations were preserved for readability. I'll take a look at the XMLFormatter, thanks.
