XMLTemplater and user parameter replacements
  • February 3, 2023
  • 50 views
lifalin2016
Forum|alt.badge.img+40
Hi list.
I got a curious error in a workspace, which I needed to update.
I needed to update some schema references (from .../1/... to .../2/...) and thought that it was a good idea to create a private user text parameter, containing the "2" needing to be inserted.
However, this yielded a strange error when applied to the root expression in my XMLTemplater. Something like this: "... can not expand namespace prefix to URI"
Is it correct that XMLTemplater cannot use user parameters replacements ?
And if so, why not ?
Aren't these applied to whatever parameters a transformer may have, prior to its execution ?
Cheers.
Best answer by lifalin2016
A potential work-around may be to create a variable with the root expression, and do the replacements there prior to using it in XMLTemplater.
Is this a viable work-around ?
lifalin2016
  • February 3, 2023
Forum|alt.badge.img+46
  • February 3, 2023
What happens if you create an attribute and set that to the value of the parameter and use that in your XML templater?
