XMLTemplater and geo data functions
  • November 14, 2013
  • 11 views
jorge_vidinha
Hi all,
Some help with an XML chalenge would be great appreciated.
Geometry Data Functions
What geometry function or functions would you use when feeding a polyline into XMLTemplater to get a final result like:
<Point>
<LAT>{value Y}</LAT>
<LON>value X}</LON>
</Point>
<Point>
<LON>{value X}</LON>
</Point>
<Point>
</Point>
geom:get-x-coord() and geom:get-y-coord() only works on Point geo, im feeding polylines and want to stay with them preferably.
Using a SUB Template like:
<Point>
    <LAT>{geom:get-points("y")}</LAT>
    <LON>{geom:get-points("x")}</LON>
</Point>
Results in ==>
<Point>
    <LAT>{value Y} {value Y} {value Y}</LAT>
    <LON>{value X} {value X} {value X}</LON>
</Point>
Any help appreciated
Jorge Vidinha
Best answer by fmelizard
Hi Jorge,
Since the lines will be preserved in the XML, if created acoordingly, you can chop your lines and feed them as points to the SUB template.
Itay
fmelizard
Forum|alt.badge.img+21
  • November 14, 2013
Hi Jorge,
Itay
