XMLFragmenter Failing with SQL query
  • Jan 23, 2020 7:04 PM UTC
  • 7 replies
  • 66 views
I have the following that works
SDE DATA => Test Filter (Name = Point) > XMLFramenter > Rest works as expected 1 feature coming through
I want to remove the Test Filter and and put an SQL Where clause at the SDE Data level ( Name = Point ) the SQL is valid and 1 feature comes through however the XMLFramenter fails.
Looking at the data in both cases for the field that contains the XML data is identical yet it fails in one case and not the other, any ideas?
Best answer by tforward
I was able to fix the issue by putting an AttributeEncoder set to UTF-8 in front of the XMLFragmeter
Forum|alt.badge.img+54
  • Jan 23, 2020 7:45 PM UTC
If you keep the test filter in even though it's now redundant, does it fail or pass?
  • Jan 23, 2020 8:08 PM UTC
Still fails
  • Jan 23, 2020 8:18 PM UTC
Still fails
What is the fme rejection code?
  • Jan 23, 2020 8:44 PM UTC
There is not one, the data goes to the "rejected side" of the XMLFragmeter. If i look at this rejected data I can see the attribute with the XML data in it and as mention before is the same as when it works
  • Jan 23, 2020 8:53 PM UTC
Hmm, I've always had a rejection code attached to the rejected record(s), e.g.
  • Jan 24, 2020 5:32 PM UTC
I've edited the post to include the error log see attached above
  • Jan 24, 2020 5:53 PM UTC
