Best Answer
XML Zip error
  • November 30, 2018
  • 47 views
runneals
Forum|alt.badge.img+29
Anyone have any ideas on how to continue around this? When I have downloaded the file myself, it seems that I can unzip it and open it just fine in like notepad++, but FME is having issues... In the past this occasionally happened, but it still ran successfully 1 out of 8 or 9 times, but it has been throwing errors the past 3 days. Need to get this resolved ASAP :)
XML Parser error: 'Error in input dataset:'www.WEBURL OF XML FILE.xml' line:1 column:15 message:exceeded byte limit at byte 'ý' in a 6-byte sequence'The XML Module halted on error, see the logfile for details
Also have been getting similar errors like
XML Parser error: 'Error in input dataset:'www.WEBURL OF XML FILE.xml' line:1 column:15 message:invalid byte '‰' at position 1 of a 1-byte sequence'
Best answer by runneals
PUE. Just changed http to https and it seems to be working again :) Will update if it occurs again.
runneals
  • November 30, 2018
