XML Templater - Xquery Loop through List Variable
I am creating an XMLtemplate that loops through all the id\\value pairs in a list and creates an XMLelement for each.
I got the looping working after reading through some of @takashi's post replys, but the $i variable is not getting passed correctly into the fme:get-attribute function on the list number. Am I going about this wrong? Is there a different way that I need to call the variable inside the function?
<update_transaction object="ObjectNameHere">
{for $i in (1 to xs:integer({fme:get-attribute("_Result_count")}))
return (
<attribute_value name="{fme:get-attribute("Inspection.Results.Result{$i}.id")}">{fme:get-attribute("Inspection.Results.Result{$i}.Value")}</attribute_value>
</update_transaction>
Best answer by bhornung
I fixed it using xquery concatenation ||
<attribute_value name="{fme:get-attribute("Inspection.Results.Result{"||$i||"}.id")}">{fme:get-attribute("Inspection.Results.Result{"||$i||"}.Value")}</attribute_value>
  • April 12, 2019
I currently am getting this when I run the Templater:
<?xml version="1.0" encoding="UTF-8"?>
<task format="sw_standard 1.0">
<task_attributes>
<assigned_to/>
<date/>
<priority>Normal</priority>
<reference_id>FileName Without Time Stamp</reference_id>
<sender/>
<title>Filename + _TM</title>
<type>Maintenance</type>
</task_attributes>
<properties/>
<data>
<update_transaction object="BuildThisInAttributeManager">
<attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/>
</update_transaction><update_transaction object="BuildThisInAttributeManager">
<attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/><attribute_value name=""/>
</data>
</task>
  • April 12, 2019
