XML Templater not get the expected result
  • Dec 2, 2018 5:35 PM UTC
  • 11 replies
  • 69 views
boubcher
Forum|alt.badge.img+11
@takashi
Hello there I have a table with the configuration bellow attribute name: fme_feature_type_name represent the parent and the attribute: name is the child, we want
to write to have an XML each parent with its child
when I use the template I am getting all features attributes name repeated for each parent name
i am sure I am missing something in the root or sub configuration
danilo_fme
Forum|alt.badge.img+58
  • Dec 2, 2018 6:29 PM UTC
Hi @boubcher
Could you share us again the images? These files are broken.
Thanks,
Danilo
  • Dec 2, 2018 10:25 PM UTC
It would be better if you would copy and paste the template expressions as-is here, rather than images. Also, please post the error messages logged when you run the workspace.
boubcher
  • Dec 3, 2018 10:22 AM UTC
@takashi
@danilo_fme
Thanks for your response
attached the excel file for the data we want to convert to XML
and the output we are looking for is
<group>
<Section>#LayerName#</Section>
<Lay erID>#LayerID#</LayerID>
<Grid GridID="Grid2555550" Color="#Color#" FilterFeild="" FilterValue="*" BufferLayer=""
<Column dataField="#id#" dataType="" summaryType="#sum#"></Column>
</Grid>
</group>
we want to replace the layer name with the value of the attribute ( fme_feature_type_name)
and the id with the value in the attribute (name )
wml templater.xlsx
boubcher
  • Dec 4, 2018 8:13 AM UTC
@takashi
Hello Takashi I did add more information to our case any suggestion
Thanks
  • Dec 4, 2018 9:13 AM UTC
Have a look at the attached workspace template, hopefully I've understood your requirements.
xmltemplater.fmwt
When there's only a single input source to the XMLTemplater, you can use the Sampler and DuplicateFilter to preprocess the input according to key attributes.
boubcher
  • Dec 4, 2018 9:48 AM UTC
xmltemplater.fmwt
@david_r
I am not able to download the WS the ulr is giving this error (
HTTP Status 403 -
  • Dec 4, 2018 10:03 AM UTC
@david_r
HTTP Status 403 -
Looks like it's the forum that's bugging.
Try this link: https://www.dropbox.com/s/g3yr27d7wpbtknu/xmltemplater.fmwt?dl=1
boubcher
  • Dec 4, 2018 10:34 AM UTC
xmltemplater.fmwt
@david_r
Thanks so much for the answer this what I was looking for
the mistake I was doing is on this
{fme:process-features("COLUMNS", "fme_feature_type_name", fme:get-attribute("fme_feature_type_name"))}
{fme:process-features("COLUMNS", fme:get-attribute("fme_feature_type_name"))}
could you please explain why should we both "fme_feature_type_name", fme:get-attribute("fme_feature_type_name")
the logic is get the columns from features type name ,
  • Dec 4, 2018 1:52 PM UTC
@david_r
The function call with this syntax executes the sub template expression for every feature (entered into the sub port) which has the specified value in the attribute. That is, it works like the Group By.
fme:process-features( <template names>, <attributes to filter>, <filter values> )
See also here to learn more: XQuery Functions
  • Dec 5, 2018 8:14 AM UTC
@david_r
In addition to what Takashi says, have a good look at the examples in the XMLTemplater help, it's pretty well documented.
boubcher
  • Dec 5, 2018 9:41 AM UTC
xmltemplater.fmwt
Thanks, Guys
really Help
