XML Templater Error
  • Mar 18, 2016 10:27 AM UTC
  • 8 replies
  • 138 views
larrybird
Hi!
While using the XMLTemplater, I sometimes come across this error:
XMLTemplater_2(XMLTemplaterFactory): The following error occurred near line 4, column 25 of the query:
XMLTemplater_2(XMLTemplaterFactory): invalid expression: syntax error, unexpected ExprSingle (missing comma "," between expressions?)
What does this mean? The XML has been pasted from XMLSpy whom have no issues with the XML. Some while ago I managed to see what was wrong myself. But instead of writing it down I thought "I will remember". I did not.
Cheers!
Best answer by david_r
Try removing the comment on line 2:
<!--Sample XML file generated by XMLSpy v2016 sp1 (x64) (http://www.altova.com)-->
The XMLTemplater seems to have issues with it, and I suspect you don't really need it?
David
  • Mar 18, 2016 11:19 AM UTC
It's difficult to say without seeing the XML in question. Could you post it here?
larrybird
  • Mar 18, 2016 12:06 PM UTC
D'oh! Of course!
<?xml version="1.0" encoding="UTF-8"?>
<vs_core:vs_Observation xmlns:gml="http://www.opengis.net/gml/3.2" xmlns:swe="http://www.opengis.net/swe/2.0" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ad="http://inspire.ec.europa.eu/schemas/ad/4.0" xmlns:gn="http://inspire.ec.europa.eu/schemas/gn/4.0" xmlns:base2="http://inspire.ec.europa.eu/schemas/base2/2.0" xmlns:vs_core="http://www.miljodatasamverkan.se/validation/core/1.0" xmlns:vs_luft="http://www.miljodatasamverkan.se/validation/luft/1.0" xsi:schemaLocation="http://www.miljodatasamverkan.se/validation/core/1.0 file://proxy.vic-metria.nu/inspire/inspire/validering/sidor/luft_smhi/xsd/Validering_Core_v1.xsd">
<vs_core:id>String</vs_core:id>
<vs_core:phenomenonTime gml:id="ID1">
<gml:beginPosition>{fme:get-attribute("InfoMatning_startTid")}</gml:beginPosition>
<gml:endPosition>{fme:get-attribute("InfoMatning_slutTid")}</gml:endPosition>
</vs_core:phenomenonTime>
<vs_core:resultQualty/>
<vs_core:resultTime>{fme:get-attribute("TodaysDate")}</vs_core:resultTime>
<vs_core:procedure>
<vs_core:analys>
<vs_core:ackredideratLaboratorium/>
<vs_core:analysInstrument>
<vs_core:beskrivning>String</vs_core:beskrivning>
<vs_core:detektionsGräns>{fme:get-attribute("InfoMatning_detektionsgrans")}</vs_core:detektionsGräns>
<vs_core:instrumentRedskap>{fme:get-attribute("InfoMatning_matutrustning")}</vs_core:instrumentRedskap>
</vs_core:analysInstrument>
<vs_core:analysMetod>
<vs_core:likvärdigMetodredovisning>{fme:get-attribute("InfoMatning_redovisningLikvardig")}</vs_core:likvärdigMetodredovisning>
<vs_core:namn>
<vs_core:namn>{fme:get-attribute("InfoMatning_analytiskTeknik")}</vs_core:namn>
</vs_core:namn>
</vs_core:analysMetod>
</vs_core:analys>
<vs_core:provtagning>
<vs_core:ackrediteradProvtagningsOrganisation>true</vs_core:ackrediteradProvtagningsOrganisation>
<vs_core:provtagninsMetod>
<vs_core:namn>
<vs_core:namn>{fme:get-attribute("InfoMatning_matProvMetod")}</vs_core:namn>
</vs_core:namn>
</vs_core:provtagninsMetod>
<vs_core:provtagningsStrategi>{fme:get-attribute("AllmanInfo_kontrollStrategi")}</vs_core:provtagningsStrategi>
</vs_core:provtagning>
</vs_core:procedure>
<vs_core:parameter>
<vs_core:platsspecifikParameter>
<vs_core:luftPlatsParameter>
<vs_luft:bilder>{fme:get-attribute("B1Info_refBilder")}</vs_luft:bilder>
<vs_luft:emissioner>
<vs_luft:emissionEnskildUppvärmning>{fme:get-attribute("B3Info_utslappEnskild")}</vs_luft:emissionEnskildUppvärmning>
<vs_luft:emissionerAvstånd>{fme:get-attribute("B3Info_avstandVag")}</vs_luft:emissionerAvstånd>
<vs_luft:emissionerNärhet>industri</vs_luft:emissionerNärhet>
<vs_luft:emissionIndustrikällor>{fme:get-attribute("B3Info_utslappIndustri")}</vs_luft:emissionIndustrikällor>
<vs_luft:emissionRelation>bostad</vs_luft:emissionRelation>
<vs_luft:emissionTrafik>{fme:get-attribute("B3Info_utslappVagtrafik")}</vs_luft:emissionTrafik>
<vs_luft:emissionÖvrigPåverkan>{fme:get-attribute("B3Info_ovrigPaverkan")}</vs_luft:emissionÖvrigPåverkan>
</vs_luft:emissioner>
<vs_luft:fasadHojd>{fme:get-attribute("B2Info_hojdOverMark")}</vs_luft:fasadHojd>
<vs_luft:gataBredd>{fme:get-attribute("B1Info_gataBredd")}</vs_luft:gataBredd>
<vs_luft:hojd>{fme:get-attribute("B1Info_hojdOverHav")}</vs_luft:hojd>
<vs_luft:invånarantal>{fme:get-attribute("AllmanInfo_invanarAntal")}</vs_luft:invånarantal>
<vs_luft:kartor>{fme:get-attribute("B1Info_refKarta")}</vs_luft:kartor>
<vs_luft:kommunLan>{fme:get-attribute("B1Info_kommunKod")}</vs_luft:kommunLan>
<vs_luft:lokalaSpridningsförutsättningar>{fme:get-attribute("B1Info_lokalaSpridnings")}</vs_luft:lokalaSpridningsförutsättningar>
<vs_luft:luftIntag>
<vs_luft:luftIntagAvståndFasadVägkant>{fme:get-attribute("B2Info_avstandVagkant")}</vs_luft:luftIntagAvståndFasadVägkant>
<vs_luft:luftIntagAvståndVägkorsning>{fme:get-attribute("B2Info_avstandVagkors")}</vs_luft:luftIntagAvståndVägkorsning>
<vs_luft:luftIntagHojd>{fme:get-attribute("B2Info_hojdOverMark")}</vs_luft:luftIntagHojd>
<vs_luft:luftIntagPosition>{fme:get-attribute("B2Info_n_kordLuftintag")}</vs_luft:luftIntagPosition>
</vs_luft:luftIntag>
<vs_luft:meteorologiskaParametrar></vs_luft:meteorologiskaParametrar>
<vs_luft:regionalaSpridningsförutsättningar>{fme:get-attribute("B1Info_regionalSpridnings")}</vs_luft:regionalaSpridningsförutsättningar>
<vs_luft:skyltadHastighet>{fme:get-attribute("B1Info_skyltadHastighet")}</vs_luft:skyltadHastighet>
<vs_luft:tungTrafik>{fme:get-attribute("B1Info_andelTungTrafik")}</vs_luft:tungTrafik>
<vs_luft:typAvMätstation>{fme:get-attribute("B1Info_typAvMatplats")}</vs_luft:typAvMätstation>
<vs_luft:uppmättaParametrar>{fme:get-attribute("fororening")}</vs_luft:uppmättaParametrar>
<vs_luft:ÅDT>{fme:get-attribute("B1Info_adtVolym")}</vs_luft:ÅDT>
</vs_core:luftPlatsParameter>
</vs_core:platsspecifikParameter>
<vs_core:tillfällesspecifikParameter>
<vs_core:luftTillfällesspecifikParameter>
<vs_luft:dataFångst></vs_luft:dataFångst>
<vs_luft:kvalitetsprogram>{fme:get-attribute("AllmanInfo_kvalitetProgram")}</vs_luft:kvalitetsprogram>
<vs_luft:maxHalt>{fme:get-attribute("maxhalt")}</vs_luft:maxHalt>
<vs_luft:minHalt>{fme:get-attribute("minhalt")}</vs_luft:minHalt>
<vs_luft:programSamordnadKontroll>true</vs_luft:programSamordnadKontroll>
<vs_luft:tidsreferens>lokalTid</vs_luft:tidsreferens>
<vs_luft:tidstäckning>{fme:get-attribute("tidstackning")}</vs_luft:tidstäckning>
</vs_core:luftTillfällesspecifikParameter>
</vs_core:tillfällesspecifikParameter>
</vs_core:parameter>
<vs_core:observedProperty>miljögifterILuft</vs_core:observedProperty>
<vs_core:featureOfInterest></vs_core:featureOfInterest>
<vs_core:result>
<vs_core:resultat>
<swe:elementCount>
<swe:Count>
<swe:value>{fme:get-attribute("matningar")}</swe:value>
</swe:Count>
</swe:elementCount>
<swe:elementType name="fixedObservation"></swe:elementType>
<swe:encoding>
<swe:TextEncoding blockSeparator="@@" decimalSeparator="," tokenSeparator=";"/>
</swe:encoding>
<swe:values>
{fme:get-attribute("_concatenated")}
</swe:values>
</vs_core:resultat>
</vs_core:result>
<vs_core:metadata>
<vs_core:beställare>
<base2:individualName>
<gco:CharacterString>Matthew Ross-Jones</gco:CharacterString>
</base2:individualName>
<base2:organisationName>
<gco:CharacterString>Naturvårdsverket</gco:CharacterString>
</base2:organisationName>
</vs_core:beställare>
<vs_core:datavärd>
<gco:CharacterString>SMHI</gco:CharacterString>
<base2:contact>
<base2:Contact>
<base2:electronicMailAddress>datavardluft@smhi.se</base2:electronicMailAddress>
<base2:telephoneVoice>018-100 100</base2:telephoneVoice>
<base2:website>http://www.smhi.se</base2:website>
</base2:Contact>
</base2:contact>
</vs_core:datavärd>
<vs_core:sekretess>false</vs_core:sekretess>
<vs_core:status>preliminära</vs_core:status>
<vs_core:syfte>Miljöövervakning</vs_core:syfte>
<vs_core:utförare>
<gco:CharacterString>{fme:get-attribute("AllmanInfo_namnRapportor")}</gco:CharacterString>
<base2:contact>
<base2:Contact>
<base2:electronicMailAddress>{fme:get-attribute("AllmanInfo_epost")}</base2:electronicMailAddress>
<base2:telephoneVoice>{fme:get-attribute("AllmanInfo_teleNr")}</base2:telephoneVoice>
<base2:website>{fme:get-attribute("AllmanInfo_adressWebbplats")}</base2:website>
</base2:Contact>
</base2:contact>
</vs_core:utförare>
</vs_core:metadata>
</vs_core:vs_Observation>
  • Mar 18, 2016 12:36 PM UTC
David
larrybird
  • Mar 18, 2016 12:41 PM UTC
David
You are absolutely right, nice one. So the templater reads into the "comments", that has been noted now =)
Cheers!
mark2atsafe
Forum|alt.badge.img+59
Looks like this is a known issue. PR#66471 and PR#26656 are the reference numbers in case you need to check with us. They are flagged for fixing in FME2017, so here's hoping.
chriswilson
Forum|alt.badge.img+29
  • Oct 24, 2017 10:02 PM UTC
Hi @Mark2AtSafe, I'm working in 2017.1.1 (build 17650) and have also just had this issue come up, so it doesn't appear to be fixed in 2017. Again it is objecting to a commented line, which will be problematic as the XML I am trying to work with contains comments left, right and centre.
mark2atsafe
Yes, I checked and it got bumped. I've added your details and increased the priority, which is about as much as I can do to force the issue. Sorry, I know it must be frustrating. But the status is now "in progress" at least. If you don't have a good workaround then let me know and I can ask the developer what we can do to avoid the error.
chriswilson
  • Oct 25, 2017 12:52 AM UTC
Workaround is to remove the commented lines as @david_r advised below, which isn't great but it does allow the XML to be created.
