XML sensor readings via HTTP
  • Aug 13, 2018 7:51 PM UTC
  • 6 replies
  • 85 views
I'm getting the most current readings for streams via an xml table provided by http link. I want to make 2 tables of the readings: 1-with the most current readings and one with the history or previous days readings. What I have so far set-up in FME does the job but I cant seem to seperate "history" from "current". Also I need the time format to stay in UTC-GMT in the AttributeCreator_2 (see screenshots). I'm trying to make a live feed map in arcpro of the sensor readings so any help would be appreciated as I am totally new to FME ANYTHING!
Thanks!
Best answer by stalknecht
To separate the two streams you need either a Tester or a TestFilter.
FME's format is UTC see: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/!Transformer_Parameters/standard_fme_date_time_format.htm
What's also handy when you begin is to look at the free training material: https://www.safe.com/training/recorded/fme-desktop-2018-basic-course/
stalknecht
Forum|alt.badge.img+22
  • Aug 13, 2018 9:03 PM UTC
Okay yes I found out that the DateTime Formatter was the best to use but I'm not quite sure what to but in the string. Also thank you for the help!
Forum|alt.badge.img+54
  • Aug 14, 2018 3:59 PM UTC
How are you defining most current readings? The most recent, ones taken today, ones taken in the past 24 hours?
If you want anything with a date that matches today you could test like this
Ones taken the past 24 hours but I need the time to stay in UTC (GMT)
Also I have stream gauges and rain sites as 2 feature layers in arcmap/arcpro. FME is being used to generate the tables with the sensor information. I constantly have to Run Translation in FME to update the table in ArcCatalog but is there a way to have FME constantly running so the table is frequently updated with the most current sensor information?
  • Aug 14, 2018 5:44 PM UTC
The tester alters the format for the test but does not change the underlying data.
But if you want past 24 hours you want to test for greater than @DateTimeAdd(@DateTimeNow(),-PT24H)
