I am having an issue with feature readers and XML. I have a process which downloads an XML file from an ftp site, and the file name changes daily. Upon download, I am trying to trigger a second process which reads the downloaded xml, so I can then split it into separate records (hence why reading in as text will not work, as I need the xml fragments). I use a path reader, to get the file name, but when I put ‘Path_Windows’ as the dataset, i get this error:
If I choose to ignore the message, and run to the featurereader, It reads in the correct amount of records (59), but the schema is blank.
Now, i know for a fact that my xml does in fact, have a schema, because if I hard code the file name in the feature reader, it works perfectly fine. (see below)
The parameters are identical on both.
I am at a total loss as to why when I want to put in a dynamic file name, the whole process falls over. If I was just writing the xml out, I would read it in as a txt file as a work around, but because I need to process the xml a certain way, i need those xml fragments in order to get my desired output.
I am in no way an xml expert, so any help would be appreciated!
FME(R) 2021.2.6.0 (20220727 - Build 21821 - WIN32)
