XML file that I need to generate a chart from
  • Jan 25, 2019 5:03 PM UTC
  • 60 views
I am trying to parse an XML file to generate a chart. I am not exactly sure how do do this and could use some help. These should be data series line graph of temperature, salinity, and sound velocity by water depth.
Here is an xml example file!
daveatsafe
Forum|alt.badge.img+24
  • Jan 26, 2019 12:15 AM UTC
Hi @ginabrewer,
A combination of the XML reader and the ChartGenerator should produce the results you are looking for.
I am attaching an example workspace for you:
xmlchart.fmw
The Temperature and Salinity values have similar ranges, so can be combined into a single chart.
Result:
The Sound Velocity has a very different range, so needs a separate chart:
