XLS writer: set specific cell value
I'm creating a transformer and getting an XLS output starting to write on row 2. I've successfully set a template for the header and format, however I need to write specific data such as date or file description in the top row.
How can I write the Document title on cell A1, Author on cell B1, DDMMYY on cell C1?
Best answer by takashi
Hi @heboma, you can control cell positions to write specific values through using some Excel writer feature type parameters.
  • Output Field Names: Set "No" not to write field names.
  • Use Attribute Names As Column Positions: Set "Yes" so that attribute names (A, B, C, ...) determine the column positions.
  • Row Number Attribute: Set an attribute that stores "1", in order to the values will be written into the first row.
See also this screenshot.
fmelizard
Forum|alt.badge.img+18
  • August 8, 2017
Hi @heboma, have you tried defining the attribute names with an AttributeCreator or AttributeManager? Do these attribute names need to be created dynamically?
danilo_fme
Forum|alt.badge.img+44
  • August 9, 2017
Hello @heboma, on the last year i created a Workspace that has your goal.
By the way has a interessant Webinar about format xls format Webinar Excel.
fluxo-gravar-celula.fmwt
Please, see attached.
Thanks,
Danilo
  • August 9, 2017
Thanks,
Danilo
thanks @takashi @danilo_inovacao Great idea! Looks good, I just need to be able to insert the value above my data table as it is part of the header and not the data.
