xfMAP extract parent attribute
  • Feb 27, 2019 11:38 AM UTC
  • 9 replies
  • 97 views
gertner
Forum|alt.badge.img+12
Hi to all,
I have following part of XML:
<field name="ROZL_SK" conditionName="skrinNN">
<webEditable>0</webEditable>
</field>
<field name="CISLO" conditionName="skrinNN">
<nullable>0</nullable>
</field>
<field name="SJZ_ZAR">
<editable>0</editable>
</field>
<field name="DOD_ROZL" conditionName="skrinNN">
</field>
and prepared xfMap script:
<?xml version="1.0"?>
<xfMap>
<feature-map multi-feature-construction="true">
<mapping match="field">
<feature-type><extract expr="@name"/></feature-type>
</mapping>
</feature-map>
<feature-content-map>
<attributes>
<attribute><name><literal expr="ConditionName"/></name>
<value><extract expr="@conditionName"/></value></attribute>
</attributes>
<mapping match="nullable">
<attributes><attribute><name><literal expr="Nullable"/></name>
<value><extract expr="."/></value>
</attribute>
</attributes>
</mapping>
<mapping match="editable">
<attributes>
<attribute><name><literal expr="Editable"/></name>
</attribute>
</attributes>
</mapping>
<mapping match="webEditable">
<attributes>
<attribute><name><literal expr="Web Editable"/></name>
</attribute>
</attributes>
</mapping>
</feature-content-map>
</xfMap>
but I'm not able to get attribute conditionName in field element.
Can help me anyone?
Thanks
itay
Forum|alt.badge.img+19
  • Feb 27, 2019 8:11 PM UTC
Hi @gertner,
Any specific reason for using a xfMap instead of Feature Paths?
Also I have noticed that using the sample you provided with the XML reader returns an error, so I have corrected the XML and now all the values are available reading the file with Feature Paths.
Hope this helps,
Itay
gertner
  • Feb 28, 2019 8:18 AM UTC
Hi @gertner,
Hope this helps,
Itay
Hi itay, I have to use Data Interoperability Tool for ESRI ArcGIS. This tool is compatible to FME Workbench version where Feature Paths is not supported ...
  • Feb 28, 2019 8:40 AM UTC
Hi @gertner,
Hope this helps,
Itay
Surprising. Doesn't the XML reader in Esri Data Interoperability Extension have the Feature Paths option?
gertner
  • Feb 28, 2019 9:03 AM UTC
Hello takashi,
the source XML is stored in an atribute in ESRI table. I have to read this attribute using ESRI Geodatabase Reader and than parse it. I tried to use XML Flattener and XMLFeatureMapper ...
There are specific problems to parse:
<field name="NAZEV_ROZVODNA" conditionName="venovniRucni,venovniVzduchove">
<webEditable roles="KL13">1</webEditable>
</field>
Twice webEditable attribute ... that means restrictions -
in this case this attribute is not editable in WEB app for all users without users with KL13 role.
The result should be row in xls:
field name condition namenullableeditable web app yeseditable web app no
NAZEV_ROZVODNAvenovniRucni,venovniVzduchove
NOKL13ALL
Thanks for your response.
gertner
  • Feb 28, 2019 9:09 AM UTC
@takashi answer see below
  • Feb 28, 2019 9:16 AM UTC
Does the <field> element always contain two <webeditable> elements?
  • Feb 28, 2019 9:19 AM UTC
Is the value of first webEditable always 0?
Does the second webEditable always have "roles" attribute?
gertner
  • Feb 28, 2019 9:45 AM UTC
Hi @gertner,
Hope this helps,
Itay
My answer to itay wasn´t correct ... I can't use (or I don't know how to) XML reader because the XML file is stored in ESRI table in specific attribute ...
gertner
  • Feb 28, 2019 3:02 PM UTC
Solved:
<xfMap>
<feature-type>
<literal expr=";" />
</feature-type>
</mapping>
</feature-map>
<attributes>
<attribute>
<name>
<literal expr="_Nullable"/>
</name>
<value>
<extract expr="."/>
</value>
</attribute>
</attributes>
</mapping>
<attributes>
<attribute type="list">
<name>
<literal expr="_Editable"/>
</name>
<value>
<extract expr="."/>
</value>
</attribute>
<name>
<literal expr="_EditableRole"/>
</name>
<value>
<!--<extract expr="@roles"/>-->
<comparison lhs="">
<arg name="rhs"><extract expr="@roles"/></arg>
<arg name="success"><literal expr="ALL"/></arg>
<arg name="failure"><extract expr="@roles"/></arg>
</comparison>
</value>
</attribute>
</attributes>
</mapping>
<attributes>
<name>
<literal expr="_WebEditable"/>
</name>
<value>
<extract expr="."/>
</value>
</attribute>
<name>
<literal expr="_WebEditableRole"/>
</name>
<value>
<comparison lhs="">
</comparison>
</value>
</attribute>
</attributes>
</mapping>
</xfMap>
