I need to write the xlink:type in an AIXM5 file (see below)
But when I look at the User Attributes of the feature type AirspaceTimeSlice (AIXM5 writer), I can only see 3 parameters of the xlink which can be set: href, role and title.
Anybody knows how to write the xlink:type with the AIXM5 writer ?
Thanks
André
Best answer by matthieuv
When reading AIXM 5.1 it seems that information is missing as well. Probably best to file a bug report with Safe for this.
As far as I know every xlink:href in AIXM is of type simple. Maybe for now you can have a workaround where read your final output just as text and use a StringReplacer with the following settings:
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
