Writing to existing GDB w/topo, feature class datasets and domains
I thought I knew how to do this but it broke for some reason. My workspace has a GDB that contains a feature dataset that has domains assigned to a few of the feature classes and it also has topology. I set up a simple transformer to sort and do an area calc. Then, I need to write back to that same GDB while keeping the domains. I recently lost the domains assignment and when I tried to update the workbench now it fails to write anything. I've tried multiple methods and each has a failure like 'cannot delete layer that has topology' or 'cannot make edits out of an edit session'. How should I set up my writer? I'm not sure I want to overwrite existing if I can help it.
Best answer by evieatsafe
Hi @jeaner sorry for the late reply. I’m curious about how you “recently lost the domains assignment”, I would try to repair this in the application that they were originally created in (e.g. ArcGIS) and then try running your workspace again. FME is not the greatest at creating domains and relationships, but can read and write to data that has them already existing. I hope that helps!
@User17013569524995596463 sorry that you’re facing a similar issue! Could you provide us with the log file or error you are facing?
hhonrubia_ct
Participant
Hi jeaner,
I am facing the same issue, were you able to solve it?
Thanks!
evieatsafe
  • March 8, 2024
