Writing data with deprecated coordinate systems
  • May 31, 2016
  • 30 views
All,
I recently fired up FME 2015 and when trying to write data from PostGIS (in EPSG:3426) to MSSQL Spatial in CO State Plane (EPSG:2877), I get a warning that the coordinate system is deprecated and no SRID can be set on the data.
I'm using the ESRI Reprojector to set the parameters, and they have worked fine in the past.
What is strange, however, is when writing to ArcSDE Feature Classes using the same source and destination coordinate systems and reprojection parameters, there is no warning about the deprecated coordinate system and the data runs fine.
Any thoughts on the difference in behaviour between these two source formats when using the EPSG:2877 (DEPRECATED) coordinate system?
Thanks!
erik_jan
Forum|alt.badge.img+26
  • May 31, 2016
Has your MSSQL Spatial destination changed?
Could it be that a newer version of the database no longer supports the coordinate system?
  • May 31, 2016
@erik_jan - same database, same platform version...
