Writing Custom CAD Linestyles using DGN Writer
  • May 4, 2020 2:50 PM UTC
  • 96 views
I have been having trouble writing geometries into custom linestyles in dgn. I have specified the seed file in the writer parameters and have set the color, style and weights using the "From Seed File" level overrides in the writer. However, when I write out the dgn, the custom linestyles seem to be dropped.
I have attached an image with some test lines. The dgn on the right is the dgn that was written out and the dgn on the left is what I am working towards. I created my seed file by deleting all the lines I drew in the dgn on the left. Does anyone have any advice?
erik_jan
Forum|alt.badge.img+26
  • May 4, 2020 3:36 PM UTC
How to write custom line styles to DGN is described in this document:
Custom_Line_Styles
Hope this helps.
Forum|alt.badge.img+54
  • May 4, 2020 3:54 PM UTC
Are you setting the igds_style attribute?
Some info here
https://knowledge.safe.com/questions/94319/dgn-writing-custom-linestyle.html
  • Aug 3, 2020 2:34 AM UTC
I am having a similar issue, did you end up coming up with a solution?
