Writing a Zipfile
  • June 16, 2017
  • 6 replies
  • 128 views
danilo_fme
Forum|alt.badge.img+55
Hello Team,
I need to make the update process inside a existing zipfile.
The zipfile contain a shapefile and i would like to create a CSV file inside this Zipfile.
When i execute my Workspace the FME included the CSV file inside Zipfile, but the other data ( Shapefile ) is deleted.
My problem: How can i just include more file in Zipfile without delete others files included before?
Version of FME Desktop: 2016.1.3.1 ( Build 16716 ).
Attached my Workspace.
Thanks in Advance,
Best answer by erik_jan
You could use the FileCopy writer to write the existing files (copy them) and have both the FileCopy writer and CSV writer write to the same ZIP file.
I believe that should work (I tested it on a my machine)..
erik_jan
Forum|alt.badge.img+26
  • June 16, 2017
danilo_fme
  • June 16, 2017
Hi @erik_jan thanks you attention with it.
Did you use the transformer FeatureWriter?
Thanks in Advance,
erik_jan
  • June 16, 2017
Thanks in Advance,
Hi @danilo_inovacao
I used the FileCopy writer after a Creator like this:
mark2atsafe
Forum|alt.badge.img+59
I filed an enhancement request as PR#78162 to see if we can get this functionality added. I'm quite surprised no-one has suggested it before.
danilo_fme
  • June 16, 2017
Hi @danilo_inovacao
Hi @erik_jan thanks your help :) its works
danilo_fme
  • June 16, 2017
Hello @Mark2AtSafe i received two ways to execute this update from ours FME User's :@takashi and @erik_jan.... :)
Please, notify us when have this new functionality add.
