Writing a List to JSON Array
  • May 28, 2019
  • 6 replies
  • 726 views
sieblist
Participant
I want to output a feature with a list (CITY) into a correct JSON array as described below. However, that does not work. Can somebody help me with it?
"CITY" : ["Frankfurt","Hamburg","Berlin"]
Best answer by david_r
There's probably no need to use the JSONTemplater here, it comes with it's own set of challenges.
After the ListBuilder, insert a ListRenamer to make the list correspond to what the JSON writer expects:
This will rename city_list{}.CITY to just CITY{}
Result:
[{"CITY":["Frankfurt","Hamburg","Berlin"]}]
danilo_fme
Forum|alt.badge.img+53
  • May 28, 2019
Hi @sieblist
After the transformer ListBuilder use the ListConcatenator.
And the transformer JSONTemplater to create your template:
Thanks,
Danilo
danilo_fme
  • May 28, 2019
Please, see this Workspace template FMWT.
I changed the transformer JSONTemplater:
Thanks, - 27541-problem-none2json-danilo.fmw
Danilo
  • May 28, 2019
Result:
  • May 28, 2019
Result:
Here's the complete workspace: json_list.fmwt
danilo_fme
  • May 28, 2019
Result:
Thank you for endorsing the response
sieblist
Participant
  • Participant
  • May 29, 2019
Hi, thanks for your help ... especially @david_r whose tip has brought the desired result.
Greetings Steffen
