Write row count to log?
  • May 28, 2024
  • 63 views
nicholas
Forum|alt.badge.img+13
I would like to count the rows in a (Oracle) database table and then write that row count to the Translation log.
This is so that I can quickly compare the row counts of two tables against each other (as a quick way to determine if an update has occurred)
I can use SQLCreator to count the rows of the table
Select count(*) as COUNT from TABLE
This places the count as a value in a column that is output from the Result of the SQLCreator
My question is, how can I write this value to the Translation Log?
I assume I use the Shutdown Python script. But how does the script read that attribute value?
geomancer
Forum|alt.badge.img+48
  • May 28, 2024
Expose the attribute COUNT in the SQLCreator.
Next add a Logger, and edit the Log Message to show the value of COUNT.
