Write multiple pages to one pdf-file using only one PdfPageFormatter
  • November 29, 2016
  • 9 replies
  • 384 views
peteralstorp
Forum|alt.badge.img+8
Hi gurus.
Problem again. I have a varying amount of objects and I want to use only one PpdfPageFormatter to write these into separate pages of ONE pdf-file. I'm assigning every object a unique pdf_page_number and thought this would do the trick, but it doesn't.
Reading the documentation it seems like I need a new PdfPageFormatter for every new page. Can this really be correct? Or am I doing something stupid again?
Peter
Best answer by takashi
Hi @peteralstorp, how about overwriting pdf_page_number with appropriate page number after the PDFPageFormater?
fmelizard
Forum|alt.badge.img+22
  • November 29, 2016
I made a custom transformer maybe can help you
https://hub.safe.com/transformers/pdfmultipageset
  • November 29, 2016
gio
Forum|alt.badge.img+15
  • November 29, 2016
@peteralstorp
Create groups (create a group_id)from the attributes, set a counter (start count = 1) grouped by your group_id to them.
Use pdfpageformater, with default pagenumber = 1
After pdfpageformatter create attribute pdf_page_number = _count.
(like Takashi said, create pdf_page_number after the pdfpageformatter)
Just make sure to group the objects by a counter (starting at 1)
peteralstorp
  • November 29, 2016
Thank you, Corrado, I will look into this when I have more time!
peteralstorp
  • November 29, 2016
I knew it, I WAS doing something stupid! You're absolutely right, Takashi. THANKS!
peteralstorp
  • November 29, 2016
@peteralstorp
Thanks for being thorough, Gio, I sometimes need that! Will have a go at this now!
peteralstorp
  • November 29, 2016
@peteralstorp
My question was correctly answered by T. I wish I could mark both answers as CORRECT, but it's not possible. Thanks again. Peter
Forum|alt.badge.img+63
The right answer has already been given, but I would like to add this:
Make sure you don't leave any gaps in your page numbering. E.g. if you supply page numbers 1, 2, 3 and 5 the PDF Writer will make an empty page 4.
peteralstorp
  • November 30, 2016
Good, thanks!
