Write Excel file to SharePoint
  • Apr 24, 2023 1:47 PM UTC
  • 5 replies
  • 741 views
chris_acc
Forum|alt.badge.img+5
Hello,
is it possible to write an Excel file to a SharePoint site? I don't believe I wish to create a SharePoint list or a lookup but simply overwrite an existing file in a folder sat in SharePoint.
I can read a file from SharePoint in just fine using a Reader and just need the equivalent to 'write' I have tried the SharePointOnlineConnector but it's not outputting a file like I would expect.
Thanks.
Best answer by nielsgerrits
Thanks @nielsgerrits​  I struggled with the output, it just seemed to count the records and not output an actual file.
imageand I have 'Upload' selected in the Action to perform.
Looks from your description you have to perform quite a few actions simply to overwrite existing file in SharePoint.
Thanks
The SharePointOnlineConnector can return the contents of a path (List), download a specific file or folder (Download), upload a file or folder (Upload) and delete a file or folder (Delete).
It should not be very hard, outputting a file using a FeatureWriter, uploading this file using the SharePointOnlineConnector. It is just an other mindset than writing directly to a file.
nielsgerrits
Forum|alt.badge.img+67
You can upload a file using the SharePointOnlineConnector. You can choose to overwrite if the file already exists. One way to do this is:
  • Creator to initiate
  • SharePointOnlineConnector to download file.
  • FeatureReader to read downloaded file.
  • Do the modifications you want.
  • FeatureWriter to write to new file.
  • SharePointOnlineConnector to upload new file.
chris_acc
  • Apr 24, 2023 2:36 PM UTC
Thanks
nielsgerrits
  • Apr 24, 2023 2:50 PM UTC
Thanks
chris_acc
  • Apr 25, 2023 11:12 AM UTC
Thanks
Thankyou @nielsgerrits​ Yes that seems to work perfectly :-)
imageThe file is written to SharePoint
nielsgerrits
Thanks
