Write DWG file to separate files
  • Dec 2, 2022 9:15 AM UTC
  • 157 views
arash_hokm
Forum|alt.badge.img+8
Hello FME community,
I have 200 dwg files that works as tiles (mosaics) for a large area. I want to do a certain process on all DWG files and then save the file with the same name. when I read and then write all DWG files with fme, they are all saved in one DWG file.
does anyone know how I can read all DWG files at once and write them to individual DWG files.
Thanks for your support
Best answer by dustin
The name of the original DWG the feature was read from will be stored on the fme_basename format attribute. Using the document referenced by @tomfriedl​, you can set the fanout parameter of the writer to @Value(fme_basename).dwg in the Navigator panel.image
tomfriedl
Forum|alt.badge.img+14
  • Dec 2, 2022 10:08 AM UTC
dustin
Forum|alt.badge.img+36
  • Dec 2, 2022 12:02 PM UTC
arash_hokm
  • Dec 5, 2022 6:50 AM UTC
@dustin​  thank you very much. you explained very well🙂
