Workspace stops working
  • Jul 18, 2018 11:10 AM UTC
  • 78 views
caracadrian
Forum|alt.badge.img+23
I am running a workspace that generates contours on a point cloud and writes them to dwg.
Workspace stalls indefinitely, doesn't crash, I get some warnings. Only message is "Sorter(SorterFactory): Completed 7.17% of intermediate processing" in the status bar.
The .fmwt can be downloaded from here (OneDrive)
Best answer by caracadrian
Thanks @ChrisAtSafe, changing the order of the transformers (Generalizer before the LineCombiner) doesn't give the desired result, the 2DForcer workaround does.
I found another workaround: set the Conflict Resolution in the ContourGenerator transformer to Perturb Input Points On Contour Interval. I don't understand why this fixes the LineGenerator to Generalizer stall. I will submit a PR tomorrow so I can attach logs and workspace to it.
chrisatsafe
Hi @caracadrian,
I'm not sure why the workspace is stalling. However, I was able to successfully run the translation by changing the order of the transformers (Generalizer before the LineCombiner). I have attached a template with the workaround for you: contours-on-pntcloud.fmwt
It seems the original translation stalls when features are being sent from the LineCombiner to the Generalizer (as shown in the screenshot). I have submitted a PR for this issue: PR #84420.
If you would like to be notified of any updates you can also submit a problem report (please quote your Q&A; URL).
Another option is to use a 2DForcer before the LineCombiner (using the order of your original translation).
Hope this helps.
- Chris
caracadrian
  • Jul 18, 2018 5:39 PM UTC
