Workspace runner or Looping?
  • Jan 12, 2023 1:27 AM UTC
  • 163 views
smfks911
Hi altruist, I have a very large datasets of daily records of soil moisture data which a FME workspace is getting failed to process. So, I have broken down by Financial Year by using testFilter and intend to produce average SM value by FY (as you can see in the image). Now I have to use a series of other transformers on each of the FY output that need to be repeated for each FY output port. Can anyone suggest which process would do it faster so that I can do like a batch process for each FY without manually changing the trigger etc? Looking for kind response.
IterativeProcessbyFY
tomfriedl
Forum|alt.badge.img+14
  • Jan 13, 2023 7:11 AM UTC
You can create a custom transformer.
But your workflow is not dynamic. Next Year you have to change the workbench. Sorter and DuplicateFilter can also use with the attribut FY.
smfks911
  • Jan 15, 2023 11:17 PM UTC
@tomfriedl​ Thanks for your reply. Yes the workspace is not dynamic. And if I want to create custom transformer which part do you think to be included within custom transformers?
tomfriedl
  • Jan 16, 2023 6:40 AM UTC
I think that no custom transformer is needed. The number of features is also too small to require trickery.
