Workspace process just stopping at 19%
williamlin98
Forum|alt.badge.img+3
I’ve been trying to process IFC data and convert it into a GDB format, however when running it will just stop processing at 19%. The workspace as worked with other IFC datasets but with a few of them it will stop at random arbitrary percentages too.
Has anyone run into this issue before and is there a solution?
danilo_fme
Forum|alt.badge.img+44
  • April 16, 2025
Hi ​@williamlin98 Is the Feature Cache enabled? If yes, please - turn off and try run again.
hkingsbury
Forum|alt.badge.img+53
  • April 16, 2025
How long have you let it sit for?
Are the files you’re seeing this happen on particularly large? It could be that its taking some time to read in data from the next feature type.
Have you tried enabling Debug logging in Form? This may give you some more information as to what’s going on
https://support.safe.com/hc/en-us/articles/25407543387533-FME-Flow-Debugging-Toolbox-Logging-Tools
williamlin98
  • April 16, 2025
I already ran this with Feature Cache turned off. It seems to get to a random percentage and then the workspace is just no longer running as indicated by the “Run” button showing up again instead of the usual “pause” or “stop”.
williamlin98
  • April 16, 2025
I dont let it sit because I can see the process has stopped because of the “Run” appearing instead of the usual “pause” or “stop” that are there when the workspace is running.
The last 4 lines of the debug log gave this as an error:
2025-04-17 08:41:41|  99.7|  0.0|INFORM|FeatureMerger (ReferenceFactory): Processing requestors: Completed 19% of intermediate processing
2025-04-17 08:41:41|  99.7|  0.0|INFORM|Calculating alpha hull on input geometry
2025-04-17 08:41:55| 112.7| 13.0|INFORM|... Last line repeated 76 times ...
2025-04-17 08:41:55| 112.7|  0.0|ERROR |BADNEWS: Internal Error -- No Descriptive Message Available
williamlin98
  • April 17, 2025
In the end I just got rid of the Hull Replacer and it started working for other things. Then I ran into the issue of 2DForcer creating the “FME Success = Badluck” where I turned the Debug mode back on and it just started working again. Odd stuff.
