Workspace fail by command line
  • Aug 21, 2018 6:04 PM UTC
  • 84 views
mr_fme
Forum|alt.badge.img+9
My Workspace run by command line...There is one Emailer transformer and other output shapefile. When I run by FME Desktop, the workspace run properly, but when I run by Task scheduler the log file show me TOTAL FEATURES WRITTEN 0, and the e-mail wasn´t sent. What I can do?
Thank´s
Best answer by erik_jan
Main issue with running by task scheduler is usually that you are not logged in.
That means that the same network mappings and privileges are not available.
The task scheduler uses (by default) a local system account to run, and that local system account probably has no rights to access the source data and send out the email.
  • Aug 21, 2018 9:59 PM UTC
Firstly you can do check if there are some errors or warnings in the log. There could be a hint to find what you should do next.
erik_jan
Forum|alt.badge.img+26
  • Aug 21, 2018 10:18 PM UTC
mr_fme
  • Aug 21, 2018 11:26 PM UTC
Unfortunately, the log files no have Warnings or Errors
mr_fme
  • Aug 22, 2018 1:40 PM UTC
Uhuu!
Solve me problem. Thank´s for your attention.
