Workflow for transposing attributes into rows
  • Apr 28, 2025 1:00 AM UTC
  • 163 views
smishsmosh
Participant
Hello all,
Complete FME newbie here
I need to transform the data compiled by a different department as an excel spreadsheet to look like this:
From
Initial structure
To
Final structure
Basically the idea is to pair each of the projects with each of the areas in order to then join the final table to a different spatial table on the ‘AREA’ attribute, ideally without manual input into transformers. The project attribute will have new entries added to it, with corresponding counts, the areas will remain the same.
Thank you.
Best answer by crutledge
Hi ​@smishsmosh (love the name :D)
The AttributeExploder is great in this case:
Transposing Data for Business Intelligence – FME Support Center
Also here is a great article on all things transposing:
Transpose a Table Using FME – FME Support Center
Hope that helps!
crutledge
Forum|alt.badge.img+55
  • Apr 28, 2025 2:11 AM UTC
Hope that helps!
smishsmosh
Participant
  • Participant
  • Apr 28, 2025 3:24 AM UTC
That’s great, thank you so much
