Word boundaries inside Inline Querier
  • Jul 17, 2018 6:27 AM UTC
  • 8 replies
  • 97 views
Hi all,
I have this SQL query in InlineQuerier that helps me join tables on specific keywords(table_b.id):
SELECT *
FROM table_a
JOIN table_b
ON table_a.id
LIKE '%' || table_b.id || '%'
but I would like to take it to the next level and also add word boundaries to my keywords, otherwise the expression is too greedy.
Can anybody help out with the syntax? (I was trying to add REGEXP and [[:<:]], [[:>:]], but so far I'm only getting syntax errors).
Thanks,
Linda
  • Jul 17, 2018 6:54 AM UTC
I don't think SQL for the InlineQuerier (i.e. standard components of SQLite) supports the REGEXP operator. You will have to think of other (or additional) approach. What pattern should "table_a.id" match?
  • Jul 17, 2018 7:17 AM UTC
There are two tables, one containing the keyword and ID, other one full names and I'd like to assign an ID based on the keyword, like this.
Table 1:IDKeyword111Starbucks321Golden Tulip555ZZTable 2:
Place NameAmsterdam Golden Tulip HotelStarbucks AirportGolden Plazza HotelResulting table should be: Place NameIDAmsterdam Golden Tulip Hotel321Starbucks Airport111Golden Plazza Hotel- In this example "Golden Plazza Hotel" shouldn't get any ID as it doesn't have any of the keywords, but when using this SQL statement: SELECT * FROM table_a JOIN table_b ON table_a.id LIKE '%' || table_b.id || '%' it picks up ID 555 as the Place name "Golden Plazza Hotel" contains 'zz'. That's why I was thinking of word boundaries that could help me to make the expression less greedy and solve this issue. If REGEXP is not an option, is there anything else I could try?
  • Jul 17, 2018 8:03 AM UTC
An easy workaround is to filter out undesired matching with the StringSearcher.
SQL Statement in the InlineQuerier
select a."Place Name", b."ID", b."Keyword"
from "Table2" as a
left outer join "Table1" as b
on a."Place Name" like '%'||b."Keyword"||'%'
Regular Expression in the StringSearcher
[[:<:]]@Value(Keyword)[[:>:]]
  • Jul 17, 2018 12:21 PM UTC
from "Table2" as a
Great, exactly what I was looking for. Thank you @takashi
  • Jul 17, 2018 12:40 PM UTC
Good to hear. The workflow was able to be simpler a bit.
  • Jul 17, 2018 3:07 PM UTC
Nice!
I have a follow-up question: While running my workbench I noticed that in those cases when the Place name can have two possible keywords, in the resulting table it will create a duplicate (it will take the same place twice each time assigning different ID).
For example,
The place name is: Best Western Premier Budapest
Keywords:
Best Western id 54
Best Western Premier id 654
For now the new place will be taken twice with each of the id this way creating a duplicate:
Best Western Premier Budapest id 54
Best Western Premier Budapest id 654
Is there any way to prevent it, some way to make it select the longest keyword or even just the first one that is found?
Thanks!
  • Jul 17, 2018 3:23 PM UTC
A possible way is to sort the features by length (number of characters) of Keyword descending and then filter out duplicate Place Name(s).
  • Jul 17, 2018 3:42 PM UTC
Perfect! Now everything is just as it should.
Thanks again @takashi!
