WMS Imagery not showing via FeatureReader
  • Oct 30, 2019 1:41 PM UTC
  • 86 views
Hello,
I am trying to read WMS imagery data via a FeatureReader, but the resulting output (using a Bufferer transformer) is just a single coloured box with no image. Can anyone tell me where I'm going wrong? Snapshots of the FeatureReader are as follows:
mark2atsafe
Forum|alt.badge.img+59
Maybe a different spatial filter? Overlaps instead of contains?
gio
Forum|alt.badge.img+15
  • Oct 30, 2019 4:44 PM UTC
@cjones28
I do that and it works like a charm. Except I use "initiator intersects result" rather then inside.
Make sure your projections match, of course. A reprojector on your initiator if needed.
Bufferer is ok, but I would then use a boundingboxreplacer on the buffer result as I understand it to be a circle. (check the capabilities file)
Or use "Boundingbox Intersects Result"
edit:
I tried it out by replace my grid by circles based on their centerpoint. This results in blank (white) results.
So it is the circular buffer that causes it.
