Why the process of reprojection from geographic coordinates to projected and finally to geographic coordinates, produces a very tiny displacement from the original information.
  • February 13, 2023
  • 89 views
rubeng
If I reproject geographic information from geographic coordinates to projected coordinates, and before I convert to geographic coordinates again, the final information has a little displacement regard the original information. I don´t have any other process in between. The displacement is very tiny, but I need to know why is it produced. I´ve make the same process in Arcgis and it doesn´t appear this displacement.
I can see the displacement in QGIS because this application allows to make a very big zoom to the information. I think that ArcGis doesn´t allow to make such a very big zoom.
Best answer by rubeng
I can´t do that, beacause in between the projection transformations I will change the geometry splitting many features. And after splitting features I need to get back to geographic coordinates.
But I think I´ve found the solution. There is a transformer called "esrireprojector" that works good, without displacement after the reprojections . This transformer seems to use Arcgis reprojection library, and as I said in Arcgis there wasn't any problem with the sequence of reprojection.
Thanks.
caracadrian
Forum|alt.badge.img+23
  • February 13, 2023
It all comes down to mathematics, geometry precision (number of decimals used) and decimal to binary (and reverse) conversion.
A computer stores decimal numbers as binary (1 and 0) with a given precision (integer, float, double, signed/unsigned). When you convert from dec to bin and back to dec, if you use enough decimals, you get a different number. Generally the last decimal is different.
The same thing applies to CRS reprojection. Each operation introduces a very small conversion error, and they accumulate fast.
rubeng
  • February 13, 2023
But it is a big problem not to have the posibility of manage decimals used into the reprojection transformer, because if you need a high precision you are in trouble.
And I also have tried a similar translation with Arcgis and it doesn´t happen. The library that uses Arcgis to reproject the information seems to work with fewer decimals then.
Thanks
Forum|alt.badge.img+62
Why do you transform from geographic to projected and back to geographic? Can you maybe get away with using a GeometryExtractor to store the geometry in an attribute first, then transform to projected, do whatever you need to do there and then use a GeometryReplacer to replace the projected geometry with the original (geographic) one, thereby avoiding the second transformation alltogether?
rubeng
  • February 14, 2023
Thanks.
