why SystemCaller does not give correct exit code?
  • Dec 13, 2017 2:13 PM UTC
  • 8 replies
  • 206 views
aguan
Forum|alt.badge.img+11
I have a SystemCaller that simply deletes a file. I would assume if the deletion is successful, it would give code 0, otherwise 1. However, it always gives 0 whether the deletion is successful or not (for example, I keep the file open before hand to cause the deletion to fail). Any workaround? I could use PythonCaller to do the deletion and generate an exit code, but would be nice just do this simple operation in the SystemCaller.
Best answer by helmoet
Try PythonCaller using the follwing script:
import fme
import fmeobjects
import os
def killFile(feature):
    try:
        os.remove("e:\\data\\temp\\test.txt")
        stat = 0
    except WindowsError:
        stat = 1
    feature.setAttribute ('stat', stat)
    pass
When called, after execution the feature would contain an attribute stat having value of 0 (succeed) or 1 (failed) depending if the delete operation deleted the file.
  • Dec 13, 2017 2:29 PM UTC
Which command are you using in the SystemCaller? If you're using "del", that command always return 0, which is what the SystemCaller will return as well.
See the documentation: https://ss64.com/nt/del.html
Errorlevels: DEL will return an Errorlevel of 0, irrespective if the delete succeeds or fails for any reason.
helmoet
Forum|alt.badge.img+8
  • Dec 13, 2017 3:13 PM UTC
import fme
import fmeobjects
import os
    try:
        stat = 0
        stat = 1
    pass
aguan
  • Dec 13, 2017 9:20 PM UTC
I see. Yes I use del command. Will change to use PythonCaller then.
aguan
  • Dec 13, 2017 9:22 PM UTC
import fme
import fmeobjects
import os
    try:
        stat = 0
        stat = 1
    pass
@helmoet. Thanks for the handy code. That is what I need when the systemCaller does not return failure code for "del file" command.
Forum|alt.badge.img+63
Funny... my SystemCaller with a del command always returns 1... and always seems to fail deleting the file.
  • Mar 28, 2018 9:02 AM UTC
The del command may set errorlevel to 1 if you have specified an invalid switch, e.g. "/X". That's the only scenario (that I know of) where del will set the errorlevel to anything else than 0.
I'm not going to bother with it to be honest, it turns out @helmoet's Python script does the trick just fine and is a much more elegant solution that what I was cobbling together (SystemCaller / FileExistenceChecker)
  • Mar 28, 2018 9:08 AM UTC
I agree :-)
